Hi All,
I have not been on here for a while because my 1928 Tudor has been running just fine. Just regular maintenance. Last week I startarted the Tudor. Keep in mind i have not driven in it about 3 months. I started right up- for about 40 seconds. Then it stopped. I tried to start it again and it would not start. The batter is fine and I checked the plugs. I use the original style plugs. I cleaned the plugs but they seemed fine. The gap was good. I hooked up a 6v battery charger and let it run for about 15 min. It how showes 6.3v. But when I turn on the key the ammeter does not move. It stays at zero. Even when I am trying to start it. Everything else works-lights and horn and dash light. The ammeter does move to the left when I turn on the light or use the horn. I looked at the points and they appear clean. What has me baffled is why did it run for 40 seconds and then stop. I also checked to make sure the carb was getting fuel. And it is. I checked the filter in the carb and it was clean. What am I missing. I have not had any issues with this car starting in a very long time. Any ideas would be most appreciated.
Thanks-Randy
Thanks-Randy
