I finally got the float valve changed.
Gas is no longer coming from the vent but is dripping from the carb inlet end.
Engine will only run with the spray needle closed.
Now what?
Thanx
Could be the gasket on the float valve. Its either that or the float is too high or - you used a Grose Jet. They don't work reliably for whatever reason.
