I had a crankshaft that was verrry bad. When overhauling the engine, first time in its life, the crank was checked. It was found that the factory must have had a trainee on this one. The balance holes were out of position by 180 degrees. When they were welded closed and the crank was then re balanced then by drilling similar sized holes 180 degrees from original holes. Wow.
