NEW products available thread
United Pacific has announced they have 1937 taillights available, RH and LH.
https://classic.upauto.com/17-led-t...-housing-ss-rim-for-1937-ford-car-rh-FTL3711R
Item No.FTL3711R
Several NEW items on our store that came in this week.
NOT new but back, 1932-35 firewall insulator bolts. This will be our last run of these likely.
https://thirdgenauto.com/product/19...r-pad-to-firewall-shouldered-screw-sold-each/
This one I'm excited about... Front shift fork 3" to use your original 32-35 housing with 39 later gears
https://thirdgenauto.com/product/19...h-original-shifter-housing-and-1939-48-gears/
1939-50 shifter shaft rails
https://thirdgenauto.com/product/1936-50-ford-low-reverse-shifter-rail-shaft/
https://thirdgenauto.com/product/19...ion-intermediate-and-high-shifter-shaft-rail/
1932-35 shifter lever lower portion
https://thirdgenauto.com/product/1932-35-ford-shifter-lever-lower-portion-new/
1932-35 Shifter gate
https://thirdgenauto.com/product/1932-35-ford-shifter-gate/
1933-34 Ford rear brake rods
https://thirdgenauto.com/product/nos-1933-34-ford-rear-brake-rod-61-3-8/
Vintique has notified dealers of parts back in stock:
[FONT=Calibri, Verdana, Helvetica, Arial]B-9002 | [/FONT]FUEL TANK 1932 STREET ROD TYPE
[FONT=Calibri, Verdana, Helvetica, Arial]B-9274 | [/FONT]FUEL PICKUP UNIT 1932 (street rod type)
[FONT=Calibri, Verdana, Helvetica, Arial]B-9700/75-S | [/FONT]CHOKE & THROTTLE RODS 32/38
[FONT=Calibri, Verdana, Helvetica, Arial]91A-9747 | [/FONT]ACCELERATOR ROD 35/48 10.75 IN
[FONT=Calibri, Verdana, Helvetica, Arial]SR-10606 | [/FONT]VOLTAGE REDUCER ELECTRONIC
[FONT=Calibri, Verdana, Helvetica, Arial]B-13027-QK12 | [/FONT]HALOGEN REFLECTOR KIT 1932 12V
[FONT=Calibri, Verdana, Helvetica, Arial]B-13027-QK12TS | [/FONT]REFLECTOR KIT WITH TURN SIGNAL
[FONT=Calibri, Verdana, Helvetica, Arial]40-13027-QK12 | [/FONT]HALOGEN REFLECTOR KIT33/34 12V
[FONT=Calibri, Verdana, Helvetica, Arial]40-13027-QK12TS | [/FONT]REFLECTOR KIT WITH TURN SIGNAL
[FONT=Calibri, Verdana, Helvetica, Arial]78-13061-K | [/FONT]HEADLAMP BUCKET HARDWARE 37/39
[FONT=Calibri, Verdana, Helvetica, Arial]91A-13061-K | [/FONT]HEADLAMP BUCKET HARDWARE 39DLX
[FONT=Calibri, Verdana, Helvetica, Arial]11A-13480 | [/FONT]STOP LIGHT SWITCH HYDRAULIC
[FONT=Calibri, Verdana, Helvetica, Arial]SR-13613-LED | [/FONT]THIRD BRAKE LAMP CHROME W/LED[FONT=Calibri, Verdana, Helvetica, Arial] [/FONT]
[FONT=Calibri, Verdana, Helvetica, Arial]B-16070-A | [/FONT]FENDER WELT 25 FT. ROLL BLACK
[FONT=Calibri, Verdana, Helvetica, Arial]B-16070-B |[/FONT]FENDER WELT 300'RL.3/16" BEAD
[FONT=Calibri, Verdana, Helvetica, Arial]21A-16349/50-A | [/FONT]FENDER GAURDS 1942/48 PASS.
[FONT=Calibri, Verdana, Helvetica, Arial]01A-16736 | [/FONT]HOOD CENTER STRIP 1940 STD
[FONT=Calibri, Verdana, Helvetica, Arial]01C-16736 | [/FONT]HOOD CENTER STRIP 40/41 PICKUP
[FONT=Calibri, Verdana, Helvetica, Arial]8A-16736 | [/FONT]HOOD CENTER STRIP 49/51 PASS
[FONT=Calibri, Verdana, Helvetica, Arial]91A-16736 | [/FONT]HOOD CENTER STRIP 1939 DLX
[FONT=Calibri, Verdana, Helvetica, Arial]SR-18402/3-PADS | [/FONT]MIRROR BASE TO BODY PADS "SR"
[FONT=Calibri, Verdana, Helvetica, Arial]11A-17758-SS | [/FONT]BUMPER BOLT 1941/48 PASS SHORT S/S
[FONT=Calibri, Verdana, Helvetica, Arial]48-17758 | [/FONT]BUMPER BOLT 33/40 S/S COVER
[FONT=Calibri, Verdana, Helvetica, Arial]A-45477-SS | [/FONT]SLIDE ARM WASHER SET S/S 28/32
[FONT=Calibri, Verdana, Helvetica, Arial]40-700616 | [/FONT]COWL VENT GASKET 33/34,35/36PU
[FONT=Calibri, Verdana, Helvetica, Arial]11A-701980 | [/FONT]LOWER DOOR SEAL KIT 1941/48
[FONT=Calibri, Verdana, Helvetica, Arial]40-701980 | [/FONT]LOWER DOOR SEAL KIT 1932/34
[FONT=Calibri, Verdana, Helvetica, Arial]48-701980 | [/FONT]LOWER DOOR SEAL KIT 1935/36
[FONT=Calibri, Verdana, Helvetica, Arial]BAAA-7022296 | [/FONT]VENT WINDOW EDGE SEAL 53/55 PU
[FONT=Calibri, Verdana, Helvetica, Arial]B6C-7022296 | [/FONT]VENT WINDOW EDGE SEAL 1956 PU
[FONT=Calibri, Verdana, Helvetica, Arial]B7C-7022296 | [/FONT]VENT WINDOW EDGE SEALS 57/60PU
[FONT=Calibri, Verdana, Helvetica, Arial]C1TZ-7022296 | [/FONT]VENT WINDOW EDGE SEALS 61/66PU
I have started making the body side (only) hinge half for 1935-1941 sedan deliveries. This is cut to length to fit the center and lower hinge on 1935-39 and upper and lower on 1941. There may be some other interchange (panel delivery?) that I have not confirmed. These are investment cast steel.
I am also working on the door side (only) hinge half, and will be working on the upper 1935-39 hinge. Rumors of the shop closing in Oregon are confirmed, this project will go with me to Texas.
That 3" fork for early trans tops is a really smart idea.
587785
