NEW products available thread
Hi David.
I did just finish up everything I needed to do to be able to accurately reproduce the ‘32 floorboards and I will always have them in stock, unless they stop making nice plywood.
Till then, here are some pictures of the ‘32 Floorboards.
Are these car or truck floorboards?
Floor Boards look too good to cover up.
Pics of capped studs used with floor mats and clips used with carpets, found (purchased) on ebay 2008
1933-34 Cowl Light Grommets
It appears both Drake and Vintique have quit on this item... So my version, 3D printed in a flexible plastic.
1935-36 Cabriolet top iron to body hinges. What I have photographed is a 3d plastic model as I will only be making these when I have a confirmed order. (I expect demand to be very underwhelming).
Karl
555187
Wiper/Hinge covers are now available for your 1937 Pickups and Trucks. I know several members here have inquired about the possibility of me making some. It’s been a long time coming. You can find them at www.nwclassicparts.com or reach out to me here via PM. Thanks!
1935-36 Phaeton top saddles.
Investment cast stainless. Unpolished for now, may offer polished later.
Top Iron Wedgies 1937-39 (rumble) convertible/cabriolet
These are the "wedgies" that mount in the top irons at the upper rear corner of each window opening. Drake sells the pad that mounts into them. These are investment cast aluminum. I will be selling each, there are uppers/lowers/RH and LH.
Re: Top Iron Wedgies 1937-39 (rumble) convertible/cabriolet
564101
