I'm clearly still in the breaking-rusty-bolts phase of the project, although today I broke only one and drilled and chiseled out another.
I wanted to remove the gas tank. I'm sure it needs to be boiled out. It's really heavy, as if when parked in 1955 it had a full tank of gas in it.
Three bolts hold it in and one bolt was stuck, so I drilled the head and chiseled off what remained. Then I took off the fender, which was a lot more work that it should have been, again, due to rust. One more bolt sacrificed.
Where the filler neck comes out of the car, in the fender.
The reason for taking the fender off was I hoped I could slide the gas tank to the driver's side and the passenger side would drop down. Once that end was lowered I could twist the tank around and get the filler neck to come through. It was not to be. I need another half inch or so to be able to get the tank past the frame. I'll try again tomorrow. Maybe I was missing something, or maybe I can unbolt the body in that area and find a little more room to work.
Anyway, skunky gas really stinks, and hours later the smell is still with me, and I hardly touched the stuff. Using a pair of vice grips I removed the drain plug and poked a punch up into the jelly and a dark red/brown liquid dribbled out. After several hours we had a quart of the stuff. Leaded, no doubt.
Richard finished painting the engine today. He really took his time, paying attention to the details. It looks great.
We'd like to be able to replace the motor mount arms, the one's that include the connection for the lower radiator hose. Does anyone know of a source for these?
Tomorrow a guy from a local body shop will come out to look at the car. He'll be making some basic sheet metal repairs, especially where the body under the rear fenders rusted and on the fenders where the running boards attach. We have a good set of spare running boards.
Mike
