Welcome to the A world: careful, it gets addicting. I have 5 and no more room or I would have more.. you're starting out with 2... that's not a healthy sign ha ha.
one thing you should know right off, these things need more frequent lubrication than you probably expect. the distributor needs a drop or two of oil and the water pump needs a shot of grease every 500 miles. Then there are all those other lube spots. The ****** leaks and needs frequent checks.
Get a copy of the " Instruction Book" that came with the car for starters. They are available in repro copies cheap and have all the lube spots and tips on double clutching, spark advance and gas adjusting valve as well as other idiosyncrasies particular to the A. Also, Les Andrew's book, "model A mechanics handbook" is a popular favorite.
hey, nice bikes, BTW
