Its not a fun job is it, Ive just been through it all. I take it you had to lock wire it up with the trans in position.. Or did you put the motor and trans in together? My lock wire pliers turned up the day after I had installed it. The six bolts I ended up using Loctite and split pins [cotter pins] bent on angles so that if the bolts did ever try backing out it would just lock up against the outer housing. Hope you have used plenty of sealant as well as those fine gaskets, gets leaky at that back end..
