Houston Rodder
Recently I purchased a 30' coupe. It idled fine but backfired at speed. The Tillotson Model X carb leaked horribly when the gas was left on. I assumed there was blockage in the carb making the vehicle run lean. So, I purchased a Tillotson rebuild kit and proceeded to rebuild the carb. The Model X was very warped which is why it was leaking. I resurfaced the carb body with sand paper and files. Now the carb goes together flush. The fuel flow from the gas tank appears sufficient.
After rebuilding the carb I reconnected everything and the vehicle started well but again it was backfiring. Timing right?
So, I hooked my test light to the coil and ground. The 6 volt bulb stays on regardless of if the ignition switch is on or off. In addition the bulb only dims and brightens as I twist the adjustment after loosening the flat head screw under the rotor.
Obviously, I am lost in matters of the ignition.
