19Fordy
I would like to install a 1/4 inch fuel outlet fitting in the lower right hand corner of my TANKS polypropylene gas tank so as to make it operate on gravity feed like the original 1940 Ford tank. The wall thickness of tank is 1/8 in. It would be very difficult to reach a nut that tightens the fitting from the inside of the tank. What type of fitting can I use?
Any ideas on what type of fuel outlet fitting I can use is very much appreciated.
Tank is pictured below. The little piece of blue tape shows where I want the fitting on the outside rear of the tank up about an inch from the bottom of tank. Thank you. Jim
PS: Exhaust pipe is to the right of the tank.
