Need choke if stalls
This. Really, I don't understand the need for choke on a warm engine if the accelerator pumps in the carbs are working. A pump of the throttle while cranking and it'll fire right up.
Tinker, I agree with your observation. I admit I’m not a carburetor expert. When :Dthey act up I send’m to guys like Charley NY!:eek::D!
Having said that the guys Telling me it’s Probly the butterflies on accelerator shaft in carb not seating closed enough causing the issue is right as if I put a strong spring on them it works & starts when warm after a couple pumps & release. As I indicated I can’t use that as resolve as accelerator pedal gets to stiff to comfortably drive.
Drolston, where do I get those radial shaft springs? I’ll give them a shot!
Mine came with progressive linkage kit. This looks like the one, on Ebay.
https://www.ebay.com/itm/333284758739?epid=1525182182&hash=item4d9951d4d3:g:h5MAAOSwdUVdQ0AW#rwid
