Flathead man2
I'm set on what I'd like to do, I'm getting the books and making a trip to Ohio to Gollers Hotrods before I pick the engine up to see how much it would be and to get a relationship built with the builder. I figure a 8BA (276?) with mild cam (good idle) port/polish and headers and the right ignition timing and if they make em E3 plugs, and full oil system with 4 ring pistons Should put me at 150 horse. Along with a tremec 5 speed, an 8 inch rear end with 4:05 gears.
Body and frame: Brookville roadsters in Ohio, 32 roadster frame, (I'm gonna tell em a Flathead is going in, with Tremec 5 speed and 8 inch rear end with 4:05 gear case. Antique green like in the avatar, with a plad bench seat. I'm gonna try to get vinyl flooring BLACK, Same plad for the rumble seat. I think so cal gages, with fender pit gard insert, hidden door handles.
Details: vitage wheel covers chrome with black wheels, chrome moon tank on the front end, old style shifter handle ya know the ones with the bends in them. Vintage tires but don't know what size would work.
Electical: 12 volt, lat 60's gen, and battery is going to be in the trunk, push button start, with a master battery switch along with a distributor switch to cut the juice to the ignition when Im at the store, gonna hide my starter button under the dash.
Cooling: Griffin radiators cross flow radiator (IF POSSIBLE), New water pumps,I heard they have better machening surfaces. Pressureised. 14 PSI
Brakes: Self adjusting brake setup and a 50's fanned brake drum covers, with residual valves, and adjustable proportioning valve for the rear brakes.
Clutch: Hydraulic clutch. Performance clutch
Suspinsion/steering: 32 front suspinsion and 32 rear suspinsion, vega steering system or stock (if I can locate one)
Sound like I got it all or am I missing something?
My mind is set.
