Hi Guys
Took delivery of my first V8 Flathead on Saturday, a 36 pickup. It came with a possible U/J failure which I have a replacement on order. Took the joint cover off at the trans end and can see the torque tube is at an angle (see pic). I can see the 2 square headed bolts that hold the trans/rear engine support are both undone and seized solid. I'm guessing that may be why the tourque tube is not square to the ******. I have run some penetrating oil around the threads which I will leave overnight.
My main reason for posting is the manual I have says to loosen rear axle and move it back enough for the torque tube to drop to the ground. Whats the best way to do this? Undo the spring at the crossmember or clamp up the shackle ends to drop the axle?
All advice welcome as I have never done this before and not too many people in London that have either!!.
Thanks
Keith
Thanks
Keith
