KULTULZ
That reference was meant for you and the 351C. Read all of it as the actual frame mounts may have to be massaged to have the mounts sit correctly.If that doesn't work then the Anchor 2725 and 2726 for fitment analysis only and replace them with the Prothane mounts if the Anchor pieces fit. Have mechanical clutch linkage so can't have the motor flopping around...
I still owe you the 55/59 steering box photos and need more info on those FE EXH MAN.
What do you have up there, a complete FOMOCO salvage yard?
