Been posting about chatter and shudder problems when taking off and down shifting.
Replaced the pressure plate, clutch disk, throw out bearing, pilot bearing and the flywheel was surfaced. I didn't do the work. Had someone else do it. Doing the same thing now as it was doing.
The guy that did the work said the motor mounts were good. I want to put new motor mounts and transmission mounts in that way I will know for sure. I can't find anything in the old manual about motor mounts. Can someone clue me in. I want to do it myself.
I am almost convinced it isn't the clutch see how it is doing the same thing with new parts. The linkage is worn but it adjust to 1 1/4" free play. Think I will just change the mounts. Any information appreciated.
