Mold
lucky
Noticed some mold inside on the cloth top an my 28 rdstr.
Anyone know what to use to remove this?
thanks, marvin
Hi,
Maybe the description of mold may also be described as mildew.
Anyway, usually mold & mildew is a living fungus which usually needs three (3) components to support its growth, i.e., (A) dirt/dust, (B) moisture or humidity, & (C) heat.
Usually mildew does not occur on: (1) very smooth clean surfaces absent of dust accumulation in crevicies, e.g., glass, marble, etc. ; (2) In regions with very dry climates & very low humidity; & (3) in areas with extreme cold temperatures & freezing conditions; hence, totally eliminate or change one of the three components, (A), (B) or (C), & one can usually prevent reoccurance of surface mildew.
Maybe first try a very mild solution of car wash liquid & water on a damp "natural" sponge to try to remove the existing mildew along with the existing accumulated (A) dirt/dust, followed by drying with paper towels.
Second, later just remove subsequent (A) dirt/dust accumulation with a damp "natural" sponge, followed by drying with paper towels.
Painters usually use 1 part Clorox to 3 parts water to totally remove mildew on existing painted wood surfaces or masonry surfaces; however, this solution may bleach the top fabric & any drippings may cause bleached spots on the upholstery below.
Hope this helps.
H. L. Chauvin
