Modifying Zenith for Air Balance
Fullraceflathead
Does anyone have the step by step article or instructions on making the necessary modifications to make the carburetor Air pressure balanced?
MAFCA magazine Restorer had that in one of their issues about 6 years ago if anybody has an index it could be found.
Do a search for Air balancing Zenith carburetors, using a larger air cleaning is a way around the problem.
Someone posted this picture a while back. You can see the vent hole is filled and the lower carb body and venturi are modified. I can only speculate that a 'port' is drilled in the body leading to the carb throat by the choke butterfly?
If I remember correctly this is how Renner's modifies the Zenith.
If I wanted to add a balance tube, I'd buy a thin brass tube from the hobby shop or hardware store that fits tight into the air vent hole. It only needs to be about 3/4" long. Then slip a piece of tubing over the brass pipe and have it enter anywhere between the choke plate and air filer. This way you can have a balanced carb for an air filter without doing any cutting or drilling to the carb.
