My 2c worth: There is very little to be gained by converting to a distributor. I just love to hear the buzz when I turn on the ignition and the zip zip zip as I drive down the road. That's what makes it a model T.
There is another alternative,
John Stoltz of "Model T Ranch", Texas, makes a distributor with a difference that's worth a look. I've been running one for 13 years now, without fault.
http://modeltranch.com/index.asp
Cheers,
Rob
Cheers,
Rob
The Stoltz distributor has an idler wheel to prevent the belt from rubbing on the cap. If not adjusted right, it will rub a hole in the cap, I know that from experience. Once I found the problem, I corrected it. You are 100% correct about the radiator needing to be pulled to work on the distributor. It is a considerable drawback.
