Repaired properly, the B distributor is very reliable and will work very well. The advance curve is well suited for not only a stock A engine with stock or a high compression head but also the Burtz engine with a 6.5:1 compression head.
The key to being able to time a B distributor correctly is to have a TDC mark on the front pulley and a timing scale so you can use a timing light. I am currently restoring eight B distributors and when finished I will use my Sun distributor machine to calibrate the advance mechanism.
Renner's Corner has some parts for the B distributor. For one to be rebuildable, you need a good usable casting, upper plate and advance mechanism. Ronner's can supply the shaft, bushings, springs for the advance mechanism and small parts kits. Cams are available, and you can use "A" condensers. The one thing that is in very limited supply are new B points. While similar, A points cannot be modified to work. I have had good success converting a B distributor to use "modern" points.
Once properly rebuilt and calibrated, B distributors are reliable and work very well. I much prefer a good B distributor over a new FS distributor any day of the week.
My experience,
Chris W.
