The '32 front brakes are a direct bolt on. Along with the backing plate assemblies and drums, you have to be sure you also have the longer operating pins. Stock Model A are 7 1/4 in, , '32 are 7 3/4 in. The extra 1/2 in. is necessary for the 1 in larger drums.
All the backing plate parts are the same as Model A except for the shoes and springs The rebuilding and set up procedure is the same as Model A.
You will wind up with larger brakes with cast iron drums on the front which is a good thing.
You will also wind up with more brake bias toward the front with '32 brakes on the front and Model A brakes on the rear which is also a good thing.
Model A's were designed with 40% front and 60% rear bias which is backwards than what it should be. Later, Ford biased the brakes more toward the front.
The '32 rear brakes are NOT a direct bolt on and modifications are required to make them work. I do not feel the modifications are worth the effort.
I have one Model A with original brakes with cast iron drums that really stops well.
I have another of my cars that has '32 brakes all around that also stops very well.
I had the '32 brakes that had good drums so I was not out a lot of money.
I like the idea of the larger cast iron drums.
I just installed '32 brakes on the front of a friends car with excellent results. It has Model A Brakes on the rear.
If you have '32 front brakes with good drums, I would rebuild them and use them. I think you would be very pleased with the results.
One thing I did on my Model A with stock brakes was to lengthen the front brake levers which will add more braking to the front. This made a big difference. This helps to bias the brakes more toward the front.
Again, this is just my experience and what I have tried and have had success with. Others, I am sure, will have other ideas which is fine with me. I am not trying to tell anyone they are wrong, I am just relating my experience.
Chris W.
