Continuation from last week-- I took generatorvand cut out switch of my other running model A and still won't start. However it is not blowing the fuse now. I have power both sides back ammeter, power both side terminal box, power at generator. I am one man show so having hard time telling if im getting spark but don't think i am. If I pull wire off bottom of coil going to distributer and put test light in plug in it barely lights the test light -- very very dim. I have checked my brake switch rod and it moved back and forth fine. I have put in a new condenser as well. I'm thinking the coil might be bad even though it's putting out little power or enough to barely light the test light. Am I missing something ?? Also anyone know trick to turn car over while I'm under hood looking for spark in the points???
