Bud Man
Well, my motor is back from the rebuilder, and its time to mount the oil pan and flywheel housing. Would really appreciate any input to some questions I have before I proceed.
1. The pan gaskets are cork. Is it better to use sealant on the engine or the pan side, or both? Or would you recommend just a small amount to tack the gasket to keep it positioned against the block?
2. Does the rear cork seal butt up against the gasket where it is cut to index into the seal groove, and am I correct to assume some sealant is used there at those junctures?
3. Rubber one-piece seal in front. Is that left alone, or is there sealant applied on front pan groove where the seal resides as additional leak insurance or does it just rely on the crush fit?
4. Is the gasket used between the block and the flywheel housing installed dry or is sealant used on it?
First A engine for me, and just trying to get it right. Tips much appreciated!
Bud
Bud
