The info below info is from this link
http://www.mafca.com/tqa_electrical.html
"To change the Model A horn from 6 volts to 12 volts, you must rewind the two field coils. Leave the armature as it is. First disassemble the horn to remove the brushes and the armature. Unsolder the two wires at the connector clip ( one from each field coil.) Note the direction of winding on the coils. The two coils are wound in opposite directions. The rule of thumb is that when you double the voltage, you use 1/2 the wire size and double the turns. So going from 6v to 12v use 24 gauge wire (original wire is 20 gauge, 1/2 that size is 23 gauge, but almost impossible to find 23 gauge so I have always used 24 gauge readily available at Radio Shack). Six volt coils have 45 turns and I have been using 100 turns with 24 gauge wire with great success. Be sure to use coated wire, normally used to wind RF radio coils or speaker coils. After winding the horn coils I usually brush a coat of light varnish to help insulate. The windings do not need to be real tight or in neat rows. In fact I found that if I wrapped just tight enough to form the wire around the core, and laid about 6 or 7 turns per layer, without being too careful how straight each wind was, I got better results on horn operation. In looking at a lot of original horns, some were manufactured with very precise and straight windings and some were wound very haphazardly."
