Brendan
Is it dangerous to a stock engine to try to run it at a higher rpm.
i don't like to spin my my motor over 2200, after that it seems like it want's to come apart
It would seem to be too stress for an 80 year old engine to spin too fast, just it would be for an 80 year old person to run to fast!i don't like to spin my my motor over 2200, after that it seems like it want's to come apart
With your improvements what do you think you new HP is? maybe..55 HP?'31 coupe. 5.5 iron head, Mallory distributor, red's header, Cragar single down draft manifold, Carter 7/16th carb, modified '33 water pump, stock cam-crank-pistons-valves, tremec 4-speed, external oil filter, 12 volt ignition, external timing mark. Runs like a champ all day at 55-60. Must be the ******.
you are right, HP is not really important, only how your car runs and how you enjoy it.Sorry, old age affects me. The Carter is 15/16th bore. As far as HP, don't really know or care, only how it runs.
