Jake dalka
I’ve read that not much sheet metal is interchangeable between a 1939 Mercury and a 1939 Ford of the same body style…..is the Mercury interior and exterior wider than a Ford ?
The answer to the first statement is NONE is interchangeable, the answer to your question is YES.I’ve read that not much sheet metal is interchangeable between a 1939 Mercury and a 1939 Ford of the same body style…..is the Mercury interior and exterior wider than a Ford ?
NO SIR, unfortunately. Ask me how I know....I've tried 39 deluxe & Standard Ford they are narrower, the hole for the shifter and for the peddles do not match up, you either have to cut one or the other to make it work but THEN you still have floor board showing on both sides by the doors AS well as it throws the length off SO you have extra that has to be stuffed under the seat or more up the firewall of the car!!!!Well thanks….is there a vender that provides a front floor mat specifically for a 1939 Mercury
Just for the record, no difference between the standard and deluxe (Ford) mats.NO SIR, unfortunately. Ask me how I know....I've tried 39 deluxe & Standard Ford they are narrower, the hole for the shifter and for the peddles do not match up, you either have to cut one or the other to make it work but THEN you still have floor board showing on both sides by the doors AS well as it throws the length off SO you have extra that has to be stuffed under the seat or more up the firewall of the car!!!!
I have "heard" but never tried that one from a 41 Ford is "close" (wider) and can work but you have to cut the whole for the shifter....and I cannot vouch for the color OR If the above is true!!!!
You will ALSO find the same for the floorboard rubber seals....You will have to buy TWO set for 39 deluxe and cut and paste with rubber cement IF you want to have floor board seals!!!!
Thanks KubeJust for the record, no difference between the standard and deluxe (Ford) mats.
Thanks Kube
Yes, ignorance Is costly!!!! I didn't mention that fact as I didn't think it necessary for the intended vehicle application. My bad.
