Squally
It's also best to use the master cutoff switch on the ground cable.
A lot of people recommend an additional ground cable to the transmission housing. If you have that then you'd have to do it at the starter, correct?
I take it that this short cable attached to the switch handle passes thru to the passenger compartment. It can turn off the switch. Do you have to open the hood in order to reset the switch?
Thanks,
