jeepguy1948
What is the proper torque for the manifold studs? I believe that I read somewhere that 55# is the proper torque. Is 55# correct?
There are hundreds of folks on the Barn and elsewhere complaining of manifold leaks so that’s a good reason to get em tight. I have grade 8 nuts and the studs are the same size as the head studs so should be able to handle 55# easily. I’m not sure that there is a downside for the higher torque (I can understand it if there were brass nuts but they’re not.
