magneto points for anlz cnversion to ford
Fordestes
I have searched the archives for the part number for the magneto points part numbers to convert an LZ to ford to a dual coil , what is the number for the points , the last ones I bought were from air spruce I remember they offered two types one set with a spring and one without the spring
can someone tell me what the correct part numbers are and do I need the ones with the spring or without, It's been too long ago thanks .
fordestes
There are a couple different part numbers:
orginal article # 10-52344W and newer number is : 10-357174
available here
http://www.chiefaircraft.com/bdx-10-357174.html
Harmon Collins uses the same points as well.... I do have a couple pairs in stock if ya cant get them. $125 per set.....(1 pair )
I also have the orginal Car Craft articles with complete direction for making the LZ into this distributor... Car Craft April, May and June 1954..
Available on ebay right now , pretty cheap...
http://www.ebay.com/sch/i.html?_odk...+1954.TRS0&_nkw=car+craft+april+1954&_sacat=0
Need it synced when done let me know.......
Thanks Jim,
I will no doubt need your services, do you know who I may get to grind the shaft and remove the perspective lobes that are called for to be removed ? your price on the points reasonable to me, which ford dist. is the best one to use to have a good curve?
I was considering maybe setting the dist. shaft/lobe assembly in my lathe and maybe using a degree wheel to grind off the un needed lobes using my DU-More tool post grinder to remove the lobes not needed. But I would rather have someone more experienced do them, anyone here on the barn have any one that can handle the grinding?
Thanks
Fordestes
