lube
Pa Joe
Quick question, How does the drive shaft bearing in the front of the torque tube near the speedo gear get lubed? Only grease fitting I see is on the univesal joint cover. Thanks Joe
Pack it with grease initially, then grease from the universal joint housing, should be able to lube from then on.
