Pa Joe Senior Member Apr 2, 2011 #1 Quick question, How does the drive shaft bearing in the front of the torque tube near the speedo gear get lubed? Only grease fitting I see is on the univesal joint cover. Thanks Joe
J Jim Brierley Well-known member Apr 2, 2011 #2 I pack it like I would a wheel bearing, and hope for the best. That bearing is rarely a problem.
Glenn C. Well-known member Apr 2, 2011 #3 Pack it with grease initially, then grease from the universal joint housing, should be able to lube from then on.
D deadelvis2000 Senior Member Jun 30, 2011 #4 Are we all in agreeance? I am just about to install my bearing after a rear end rebuild and would like to know as well. Thanks
Tom Wesenberg Well-known member Jun 30, 2011 #5 What Jim and Glenn said is how I do it also. Never had a problem.
