51 MERC-CT
You may want to reconsider your assumption that shorter shocksIf you lowered the rear and didn't change the shocks(to shorter shocks) it will most certainly bottom out on the shocks.
would be required if lowering blocks were installed as it pertains to a '53.
The shocks are mounted to a plate under the springs and that location does not change in relation to the upper mount.
The only thing that moves is the axle in relation to the body.
