garyhamblin
Does anyone have any ideas on lowering my truck without using a drop axle on the front.Can I take out leaf springs and do it.Thanks Gary
Sacremento Ford in Cali. has the main leaf reversed eye or Speedway Motors where i got my springs from,which is the whole springpack. Did a 47 Ford PU with same set- up. No bumpsteer or modifcations. If you use a drop axle then you will have to use dropped tie rod ends and you might have a problem with the draglink.
