Acadia John
When driving along ( 1923 FORDOR) there is a severe clunking ( sounds like a rhythmic hammer on the exhaust pipe but we know it is not) When backing slowly it will eventually fetch up with a definite jolt. Seems like it is coming from the rear end. If you turn a wheel by hand it will fetch up at 0 and 180 degrees. If you turn the crank while in neutral there dose not seem to be that noise. Might it be spider gears binding or is there a pin that can slip out part way. Regards, John
