Clem Clement
Current clevis pins are loose in their brake lever fitting. Rathy than try and drill the lever ends and use a larger pin, can I shim the pins with soup can metal?
You have to take all the slack out of your system. Use Oversize pins, please don’t shim openings.
Everything must be right, everything.
Enjoy
So, if install a loop of steel safety wire thru the rod/lever hole beside the sloppy new pin to reduce the slop, I'm unsafe, right????
Clem, Let me pay a visit in the next week and we can take a look.
