Let me put this up here again, it won't help "already-built" units but it may help on future builds.
Install bronze liners in the guides, we started this program/procedure many years ago and to this day haven't had one single "stuck" valve!!
There are numerous reasons for this happening, the valves hanging, but most times it is moisture inside that doesn't "burn" off. It accumulates in the system especially after driving short trips and shutting down. Having owned numerous Flatheads over the years and driven miminal numbers daily (under 1 mile to the shop) this was always an issue with the exhaust systems also. Constantly replaced pipes and mufflers.
For the cost of the bronze installation, which initially may be somewhere around 8.00/9.00 per guide, it's really good insurance in the long run, just in the price of gaskets alone, not mentioning the labor involved. If your original guides are OK you just "line" and reuse them.
While knurling guides is OK, it doesn't "change" the materials involved. There is more "resistance" with the bronze liners to moisture collecting on the stems than with the cast iron guides/steel valves. You can also run slightly tighter valve-to-guide clearance in there. We do not "ream" bronze liners, they are ball-broached for sizing. Some get finished with a Sunnen valve guide hone also, not to be confused with the silicon ball-type hones, it uses actual stones and guides get I.D. measured with a bore gauge. About 99% are fine with the ball-broach setup.
Thanks, Gary in N.Y.
P.S. We would never reuse the original guide retainers (horseshoe clips) anymore, always use new pieces. I would also use some Viton stem-seals on the guides.
