rotorwrench
Just to clarify my stuck valve problem, 2 pictures showing the movement in the valve assembly with the stuck spring. Note how far out of thebore the guide will come in the down position.
Now I see what you are relating. Generally I'm dealing with motors that have not had an overhaul in many years so the guides are pretty well frozen in their bores but since yours is a recent overhaul, the guides can still easily move in their bores. I've generally noted that guides aren't all that close a clearance with the valves stems even with new parts. The phosphor bronze sleeves may be the best choice as Gofast mentioned. They are softer material for one and will not corrode for the other. When I was a kid up in Kansas, we had no problems with sticking valves but it was more than a few miles we generally had to drive and the relitive humidity average on the high plains is about 25% so it wasn't a problem there. Only the old folks that drove to church on Sunday & the post office every day had gunked up engines. They never even got warmed up. On the farm, they got warmed to peak temps every time we drove them.
If the valve to head clearance was checked during overhaul, I doubt if they hit the head unless there was a carbon build up or something
