Synchro909
Like HL, I think advice on how NOT to is just as important as how to do anything.
The only good easy outs I've ever seen or used is the ones we had in the Army. They had a straight shank with sharp barbs running the length, so as you tapped them down into the hole you drilled in the broken stud, they grabbed on without expanding the broken part. I've never seen them since I got out of the Army, but wouldn't mind finding a good set of them.
One trick with hard outs, is do not drill all the way through the broken stud. That way the easy out will hit the bottom of the stud. It will not put as much pressure on the sides of the stud, which makes it expand the stud in the block even more than it is.
