Please refer to the attached PDF (40 FORD LUBRICATION & MAINTENANCE CHART). I pulled the chart out of my DeLuxe Reference Book.
I believe the book is the original that came with the car that my Granddad purchased new. I’m the second owner. The book still has the 300 mile and 1,000 mile free inspection coupons in the back. I’m guessing the Ford garage will no longer honor those coupons.
I’m looking for some good solid advice for what might be available these days as far as equivalent lubricants for the ’40 that will not only provide adequate lubrication but also do no harm to the older seals and other sensitive components (e.g. yellow metals).
I appreciate you guys that offer up advice, but please do not reply with posts like: “I use this stuff and it works great.” That would not be helpful to me.
Here are the main lubricants that are listed on the chart that I am interested in finding currently available replacements for:
NOTE: The nomenclature used is what is listed on the Ford chart.
Pressure Gun Lubricant (probably translates to “chassis lube”) – Shown on the chart as being used anywhere there is a zerk fitting on a chassis component and the Drive Shaft Center Bearing.
Gear Oil (S.A.E. 90 and 140) – Shown for use in the Transmission.
Mild Extreme Pressure Gear Oil (S.A.E. 90 and 140) – Shown for use in the Differential and Steering Gear box.
Universal Joint Lubricant – Shown for use in the U-joint at the rear of the Transmission.
Ford Spring Lubricant (Ford Spec. M-4628) – Shown for use in the front and rear transverse leaf Springs.
Ford Wheel bearing Lubricant (Forde Spec, M-544) – Shown for use at the four Wheel Bearings.
Having been sensitized, or what some would call “ruined” or “totally messed up”, by my experience in the Navy Nuclear Power Program, and the commercial nuclear power industry, I believe in using “The “Right Stuff”. Please help me find “The Right Stuff”.
Thanks,
[FONT="]4DForDor[/FONT]
Thanks,
