Thanks Pete,
where might you find Marsden nuts?
I know a guy who uses regular nuts, with pal nuts most of his engines have upwards of 40,000 miles, nothing has come loose. That includes mine at 27,000 and no overdrive.
1955cj5
Check out Aircraft Spruce P/N AN363- just add your dash number ie 7/16-20 is a dash 720
AN363-720 $1.39 each
Mike
If you want to ruin threads, use the punched nuts.
There is nothing wrong with Castall nuts, and keys. They will never come loose if done right, as long as the threads on the bolt, and nuts are in good condition.
Herm.
