Thought i would borrow this thread rather than start a new one if that is ok.
So like, if i made my own horn/light switch rod out of solid rod with a spring at the top of the wheel so it keeps the rod from touching the contact thing at the center of the light switch, then when the rod is pressed it makes contact with the center contact would it short to ground through the column somewhere and work in the way it was intended?
You must have the time in your profile set for something other than your local time. The time stamps on mine read: #1=6:44pm, #2= 7:05pmQuestion at 02:15 a.m. and first answer at 04:29 a.m. ? When do you guys sleep?...
Mine says 10:44 and 11:05You must have the time in your profile set for something other than your local time. The time stamps on mine read: #1=6:44pm, #2= 7:05pm
