I know a 12v led will work on a 6v system as I have done it before, but that was on a negative ground. As for the positive ground, if it's a simple single wire circuit (like running a single filament bulb) then I don't see why you can't hook it up normally, the led won't know which wire is attached to the frame....a circuit is a circuit...but maybe someone else can chime in on this part of it....if that doesn't work, try reversing the wires, I think the led's you get these days have reverse polarity protection so it shouldn't bother them, or you could just buy the proper 6v posative ground led drop in that is designed for these trucks...lol
