Georgew48
Do I need to install the spring spreader before I try your method of loosening ther left side u-bolt clamp or is it safe to loosen them a little bit and tighten the right side then the left?Before committing to the hard stuff try this, crawl under the rear end. Loosen the left side spring u-bolt clamp. Tighten the right side then the left side and check the frame to floor measurements. This worked for me.
