Lean to the left
Before committing to the hard stuff try this, crawl under the rear end. Loosen the left side spring u-bolt clamp. Tighten the right side then the left side and check the frame to floor measurements. This worked for me.
Do I need to install the spring spreader before I try your method of loosening ther left side u-bolt clamp or is it safe to loosen them a little bit and tighten the right side then the left?
Had the same problem on my coupe. Turned out number three spring was broken. I highly recommend you use Slip Plate as a coating on the springs versus some type of grease. You can purchase it from Napa and use a 2 or 3 inch roller to paint it on. You should have 3 coats top and bottom on all leafs. You can see a few pictures of how we replaced mine here. Rear Spring Replacement
I also had a lean to left. The rear spring center bolt was broken causing the leafs to shift. Replaced the bolt and no more lean.
