Leaf spring alignment bolt under axle pad
I find the part about using a heat gun to cure the paint to be interesting. I have an old kitchen oven converted for use to cure parts I have powder-coated. I have also used it to cure painted small parts. It seems to help with the hardness and durability of the finish.
It helps enamel cure big time. Sometimes I even pre-heat the parts with the heat gun. Super durable. I use it on firearms quite a bit. I did this on a crappy set of combination wrenches, and it's a really tough finish. Those wrenches are still looking good after getting knocked around for over 5 years.
I'm getting to the point where I use engine enamel with ceramic (VHT) for most of my rattle can needs.
Back on the road! The difference is unbelievable. I put new shocks on all around too. It's so much better.
