Looks like spindle pin PRESSI can't imagine pulling a pin.
You will find,if and when you would use this, just how wonderful a tool it is. I have the KRW version and when I have come upon a "stuck" pin... it works with ease.
Good score!
Once you use one of these, you'll wonder how you did this job in the past without it...Here are a couple of pictures that I had found googling for info. This will also push out radius rod pins if you have the correct " upper flange" with a large opening in it (which I don't have) to fit over the flange on the pin. Bill![]()
Dare I say it!You've inspired me to build a mini one for door hinge pins. I'm sick of grinding, drilling and pounding. I have two doors to pull this week.
Dare I say it!Bob Drake makes one. A very nice cast one. Part # TL100.![]()
That is the one I have made by snapon. Will do model A on up to 48 perch pin bolts
These tools work great on king pins, but I can't begin to imagine any of these tools being able to push or pull any perch pin that is Frikken' STUCK to the axle, as MOST usually are. A 30-TON press many times won't do that job. DD
