lucky_stripe_garage
So I was worried about a bad head gasket. When running about 35-40mph the water would foam. Since I know the previous owner had rebuilt the engine (back in 1975) and ran it less than 50 miles I thought I'd start with re-torquing the head. Started at 35lbs, torqued 13 with no issues, Number 14 decided it was too much and snapped. Guess it was time to change the gasket anyways.
Not wanting to have the issue again decided it would be best to replace all the studs while the head was off. Bought a tool from the local parts store, got two studs off and snapped another before the tool broke. Exchanged the tool and had the same results. Had to step away for a few days before too much frustration set in. 4 studs removed, 3 studs snapped, 7 studs soaking with penetrating oil.
Took the stud remover back and exchanged for a different style yesterday. 3 studs removed with no issues. Put the tool on the passenger side water neck stud ensured that both valves were closed on cylinder 1, but apparently it wasn't seated all the way. The tool caught the edge of the valve and seems to have bent the stud. Now I get to do even more engine work.
