Here is the follow up on lobucrods stuff.
Test results with Lobucrod's insulation. I wish that I could have done this in the same temperature as the last but didn't want to wait untill next summer. It was only about 78 degrees on this day. I used the trunk lid on my 46 because it has nothing in the way of insulation on the inside. I attached a piece of B-Quiet, Lobuc's, jute with foil, and the airline industry stuff. With the outside temp on the decklid at 111 degrees I obtained the following results. B-Quiet 84 deg, Lobuc 84 deg, jute/foil 88 deg and airline stuff 86 deg's. Later it dawned on me that I could create heat with my "halogen lights on a pole". So I set this up in the shop and tested the Lobuc and the B-quiet on my 40 project that has the Lizard Skin sprayed on. I was able to heat the outside surface to 160 degrees. The area that I had already installed B-quiet over the LS showed 80 degrees on the interior side, the Lobuc over the LS was 85 degrees. I have pics to back this up if anyone needs to see them, well not the halogen light induced temp because the lite was too bright to take any pics. Some thoughts about what I think that I have learned. First Lobuc has a good product that I will use again. It is as good at temp reduction as B-Quiet for a lot less money. It also is lighter than B-Quiet and easy to remove if needed, I learned that removing the B-Quiet after it has been on a while is VERY hard, as it leaves a coating of tar on the surface. Yes it looks and smells like a fresh asphalt coating on a parking lot. I would not be happy to deal with this stuff after it has been on the car for awhile. This experience makes me rethink the value of using this type of stuff. I don't know how Lobucs product would stack up against B-Quiet as far as sound control goes. Also, there did not seem to be any advantage to adding a layer of Lobuc's over the B-Quiet I already have. Putting two layers of Lobuc's product together also seemed to not lower the temp reduction. My next project will probably get a coating of Lizard Skin with Lobucrod's product over it. One last thing in case you did not see my other post regarding the thickness of Lizard Skin. I was recently able to test what was sprayed on my 40 [some by me, most by an experienced shop] with an expensive device that measure mills of coating thickness. Lizard skin recommends 40 mils, my 40 varies from 10 to 20 miils. A friend that recently did the floor of his car had to apply three coats with a roller to get to 40 mils of thickness. Just FYI. Joe
