Johnnydidd
what is the best type, spray on with ceramics, blanket insulation, fitted insulation which would you use? which is the best?
I did the roof of my '54 with it 4 years ago and no problems,HUGE difference in heat reflection as I live in Phoenix,AZ. Put your hand on the exterior for less than a minute and you'll take a trip to the burn unit,totally comfortable inside.I can't say enough good about that Peel & Seal stuff. It's really great. I used the 6" wide stuff as it's easier to fit in place. Makes a HUGE difference
If I put insulation on the fire wall under the hood would that work better than inside on the fire wall?
