A-Jay
I have been waiting for cooler weather to install a 160 Deg. stat. Are there any tips from you guys, or just remove upper hose at the Radiator and throw her in ? Should I drill a couple of small 1/8" holes to re leave some pressure ?
Should the stat which has a neck on it be clamped somewhere or be loose in the hose then stop at the radiator neck? Thanks for your replys.
