mccsix
Any tips on how to get this d... dissy back in the hole? Took it out, installed a Nu -rex advance system, put it back together, fired right up and died 30 sec later. Did that a couple of times before realizing the dis wasn't seated to the head, sticking up about 1/8".
I have to keep pushing on the armored cable, line up the dis pin into the hole in the head AND align the dis slot to the shaft slot....all at the same time. Is the slot off set so that the dis can only be put in one way?
Apparently you have to sneak up on it from the drivers side to see the pin/hole alignment. My back is now officially walked off the job, and I just can't seem to get all 3 holes lined up.
Any ideas?
Any ideas?
